okay i want to set up a file server on a network for 5 computers in my house. all will have xp on them and what not. im not sure though whats the best server software for me to use. i want a simple solution where i can dump batch amounts of data for later use. i dont need it to be a power house server or anything like that. just something simple that wont be hard to set up.
THinking about using a 450mhz comp with 3 40 gigs in. would you consider maybe bumping this up to a 1 ghz comp. what kind of speed gain would i get. again dont need power now but would like to get software that i can transfer to a more powerful computer when my needs grow.
Thanks
Ryan
PS i would have searched for this but the search is off at the moment and i dont want to spend hours reading through post.
Thanks
Ryan
