Looked, but I couldn't find it anywhere... looks like a hybrid raid controller? Adaptec?
Updates at work:
Picked up a PE860, X3440, 8gb, Perc6i, 146gb SAS, and rails for $150
I now have a baller VPN server for our roadwarriors and two site to site links
Looks like a Fusion-io SSD http://www.google.com/search?q=fusi...&source=og&sa=N&hl=en&tab=wi&biw=1440&bih=771
Again, why would anyone work at such a place? The people who have the most knowledge about the requirements aren't allowed to make the correct decision, you're nothing near "perfection" -- not even near "adequate" or "sustainable". Sure, lots of companies work this way; must most companies fail, and the rest operate at an inefficiency that serves neither customer nor employee.
If lower-level employees don't have the courage to talk to people a level or two above themselves, management will never get the information they need to make better decisions if the framework remains at its status quo. Does information really never travel up the hierarchy at such companies?
Some controls are necessary. You've jumped to the conclusion that I'm suggestion people buy whatever they want without approval, or change things without any documentation or review whatsoever. That's not what I suggested, as complete autonomy doesn't work with more than four or five people.If you're a big company, imagine if every technology person bought whatever they want or even worse, changed configs whenever the felt like it without telling anyone ... the company would fall over in a matter of minutes. The larger you are, the slower you become, and the less you trust your employees ... these controls are necessary for the company to function.
was this found locally? or online...
also how do you find a local recyclers like that?
im jelly
Dash; what amde you go ScreenOS over JUNOS? just curious, as most people I talk to are going JUNOS for new deployment, and jsut using the SSG's if that's what is already on site.
Looks like he bought it for his home lab.
Just started a big project:
Couple 7Ks, lots of SUP720s, some 6509s, etc.
I came.
Wasn't this stuff all carried by an uninsurred soccer mom van or something?
Got to play around with this thing yesterday. It's a nice fast SAN but, sheesh, talk about cabling nightmare. For the record, I didn't install it, just got to play with it.
Good luck. Unisphere has to be about the most retarded SAN interface I've ever had the mispleasure of working with. Hell, even Lefthand was more intuitive.
Stunning mate, fantastic work.
Why clustered and not mirrored?The two Dell R710 servers run MSSQL 2008R2 in a clustered setup. Each server is a single quad core xeon with 24gb ram.
It looks nice and tidy, but I wonder why you route the cables so tightly. This makes it impossible to slide out a machine from the rack without disconnecting it first.Server side cabling:
Why clustered and not mirrored?.
I was also wondering this, would be a bitch for a tech like me to come in and change the main board or cpu etc etc etc etc..
Hot swapping CPU's and mainboards these days are we? Maybe a fan or some RAM would be difficult with it tied up like that, but any of the things you suggested would not be done with the machine was online or plugged in and offline for that matter. I do agree that it would be a bitch. Some rails that slide with the server would be ideal to replace things you could replace without going behind it.
If I were to accidentally kick out the bottom plugs, everything stays online because the other cables are routed to the top of the wall.
Clustered because there are quite a few databases running on the cluster. Second, I only need one license of SQL Enterprise if they're clustered.
The cables are tidy because I hate the cabling arms that come with servers from Dell, etc. I won't use them anymore. I really really loathe them. Anyway, the reason I have open racks is so that I can reach through and get to the servers easily. Also, they are a good two feet or so away from the back wall, so really easy to get back behind them. Those SuperMicro servers and Dell servers can pull out fully on the rails, as long as everything is disconnected.
One other thing...the PDU's each go to a different circuit breaker and each server has two power supplies, one to each breaker. You can see the PDU has a gray and black plugin. If I were to accidentally kick out the bottom plugs, everything stays online because the other cables are routed to the top of the wall.
By the way...that IPKVM is hooked up now and cables routed appropriately. Haha. I took the pictures before. I had to order a different length cable from Avocent so I didn't have excessive cableage. I hate excessive cables running around. My OCD gets the best of me.
