lithium726 said:probably around the same as the other revE chips, around 2.7ghz.
divider anyone?I believe ram to be my limiting factor, Mushkin HiPerf 1gig sticks. All the reviews basically state 220mhz is all I'm going to get out of them even if I relaxed the timings. Not surprisingly that's right where my system looses stability.
lithium726 said:divider anyone?
me too, ever since i found out about lancaster actuallyrobberbaron said:I've a "theory" that the manufacturing process for the X2's is similar to the Lancasters and that this could be why a lot of them don't OC too high.
(cf)Eclipse said:you're using the auto oc thing? definitly ditch it, i find they cause more problems than it's worth![]()
overclocking is a thing of patience, if you haven't got any, forget about really maxing out your rigkmeson said:Now it's all about insta-gratification.
(cf)Eclipse said:overclocking is a thing of patience, if you haven't got any, forget about really maxing out your rig
also, you don't really need to go into the bios to oc the cpu anymore, just use clockgen and a64tweaker![]()
i thought both cores scaled identicallyLBJGH said:I can get my 4200+ to 2.5ghz @ 1.4v and 2.6ghz at 1.5v but only with one core... I'm waiting for Epox to release an updated bios for my motherboard (9nda3+) so I can test the second core.
please explain. either you use both or you don't.LBJGH said:I can get my 4200+ to 2.5ghz @ 1.4v and 2.6ghz at 1.5v but only with one core... I'm waiting for Epox to release an updated bios for my motherboard (9nda3+) so I can test the second core.
maybe its like the 875 and 865 with the pentiumD, its only seeing one core with an older bios or something.(cf)Eclipse said:please explain. either you use both or you don't.
Good thinking.robberbaron said:I could probably hit 2.6, but it's not worth the heat. I can do 2.5 at 51C roughly, but I really dont want to go beyond 1.55v.
