Wireless USB vs PCMCIA
Zo-
My roomate recently picked up a cheap laptop off some kid at school. He has reformated it and set it up to his liking. One problem is that it doesn't have a wireless adapter. I was browsing online at tigerdirect Here.
My question is, are there any advantages for one over the other? I could see that the USB stick sticking out could be an annoyance, but then again so is a pcmcia card sticking out of the side.
Thanks,
Kurt
Usb has the advantage of being able to use it on mostly any computer. But you would probably lose it quicker.
For a laptop..I'd go with a PCMCIA....solely on the point of durability. A laptop will be moved around..perhaps sitting on lap, etc. A USB stick will be susceptible to being put under pressure, bumped, snapped, etc. PCMCIA..granted they still stick out a bit..but still stronger and more durable.
Sorry I haven't responded in a while, school is kicking my ass.
Thank you for the responses. So it sounds like it's just going to be a preference? I'm a little more fond of PCMCIA and agree with what you say above, and if there really isn't any performance differences i'll probably end up going that route.
