This issue is so simple that it is complicated. What are the options for sending wireless PC content to a remote home theater or big-screen set up in real time.
The solution must generate crisp looking pages that are readable. It must also play every major form of video or audio that a PC can.
I want to use standard wi-fi or something easy.
I don't mind using some form of adapter at the receive end, but not a dedicated PC.
I need to use the PC as well as media so Apple TV is not my option
I am not worried about HD content for this use...my set up covers that aspect.
I would like to spend $400 or less.
For example if I want to browse the internet (untethered) and watch a youtube on my TV...what can enable me to do that right now?
A friend told me about a product at a company he consults with that will be released by www.quartics.com this summer that seems like it can do the trick, but I have no idea if there is something as good (or better) I could get now. I had made a similar thread on this exact topic in 2002
I am hoping to have more luck now.
anything?
anything?
