Wireless Media Player
ZeroOne
Does anyone own a DSM-320 from D-Link that can let me know if you can play shoutcast, wma streaming radio ok?
Or know of one that works well that is still pretty cheap?
If you run a program like TVersity on a computer and let the D-Link connect to the computer then you are good to go. You can set up tons of bookmarks, stream music off your PC and even stream shoutcast that is running on your PC.
Example:
D-Link (192.168.0.100) ----> connected to -----> computer running Tversity (192.168.0.101)
Computer running Tversity is also running shoutcast so it is basically broadcasting all music it is playing at http://192.168.0.101/myass.pls
Make a bookmark in Tversity so the D-Link sees the bookmark. You can also share all your music so the D-link see that although I recommend Windows Media Connect for that purpose.
