`kay, I have an existing 100Mb network on 192.168.0.* I just got some gigabit cards for a song here, and I want to set `em up as a seperate (concurrent) network for local data xfer only. There's a 2kserver (gateway & DHCP server), but only 2kpro machines will get another NIC. Here's what I tried so far:
1) First up, put the Gb's on 10.0.0.* IPCONFIG said they were at 0.0.0.0, weird.
2) Switched to a 192.168.0.* IP, worked fine.
3) Went to a 192.168.1.* IP, figured I could use the netmask to my advantage this way.
4) Last thing I tried was back to a 10.0.0.* IP, worked just as steps 2 & 3 above.
From step 2 on, I could ping, map, etc. just fine. But! I got this nifty traffic monitor (ethereal) and it said there was traffic on the 100Mb card, no matter what I did.
I tried to map network drives using IP addresses, same thing. Oh, and for now the Gb cards are connected directly, so no hub / switch / etc.
I'm @ work so can't fsck with it `till tonight, but any ideas?
