80mm mechatronics which pushes 53 cfm at 39db
or 92mm ys tech which pushes 50cfm at 32 db.
heatsink is slk900.
if they were same size I would go for the ys tech but ive heard bigger fans do not cool as well as equal cfm smaller fans due to the size which means airflow is dissipated over the heatsink.
am lookin for better airflow, atm I have a 80mm ys tech which pushes 45cfm. want something better though.
so which one shall I go for?
heatsink is slk900.
