Hal Emmerich
- Jan 13, 2009
Earlier I moved my computer from one room to another, plugged everything in and turned it on only to find it turned off straight away.
Kept trying it and the computer was only staying on for maybe 1 minute maximum before it shut off. First of all I thought that when I moved my PC maybe I knocked the circuit in the PSU and it broke, so the PSU was failling. I opened it up and checked all the connections, then tried again. Same problem.
So after browsing the net for a while I read that a lot of the symptoms associated with RAM failure are also present in PSU failure. So to test whether it was RAM failure I removed one stick of RAM, tried it again and got the same problem. I tried the other stick of RAM and it booted up and managed to stay up for around 5 minutes before I turned it off, I booted it up again and it stayed up for 5 minutes before I turned it off.
At this point I was almost positive it was RAM failure, the first stick of RAM was failling near on everytime and the second stick was leaving the PC on for as long as I liked, although I never tested it for more than 7-8 minutes.
Anyways, then the RAM that I thought was working.. stopped working. It started to suffer the same fate as the other stick of RAM and was turning off after a few seconds/a minute or two. Because of the inconsistency I had no idea whether I am dealing with a PSU problem or a RAM problem..
I tried running memtest on the stick of RAM that initially worked, got halfway through test 4 and the PC shut off.. but there were no errors shown up to test 4.
It also seemed that in the early stages the longer I left the computer turned off, the longer it'd turn on the next go, which made me think it may be overheating. However all fans work, the PSU fan works etc.
Right now I'm thinking PSU problem, because of the memtest not showing any errors.
Oh, I have dual channel RAM, and when I run the PC with nothing in channel 1 and a stick in channel 2 the PC keeps restarting, which I presume it should.
A few things that crossed my mind:
What do you think? Oh and this might help:
Current status of each piece of hardware:
First stick of RAM: Boots, but will power off after a few seconds or a minute. Time varies.
Second stick of RAM: Boots, lasts longer than first stick, but still inevitably powers off.
PSU: God knows, could be working (it sends power to everything) but could be failling (random power offs)
- Reset the bios
- Try with new RAM altogether
- Take it to a shop and try a different PSU
