what would u get
BigD86
well all the 3500 winchesters are out of stock at every damn place i know about, and i have to get a processor for christmas so would u get a 3200 winchester or a 3500 newcastle. I plan to overclock just a little bit not much at all so im not sure which to get.
Thanks
P.S. And if u have any sites that i dont know about that have the 3500 winchester in stock i would appreciate it alot.
militaryman1010 said:
will a 3200+ out 90nm out oc the 3500+ 130nm?????
It's different for every chip. It's different for every chip. It's different for every chip.
Yes it will, but there are exceptions. 2.6ghz is the goal for most overclocks...some only get to 2.5ghz :D
alright thanks for the help, ill prob end up getting the 3200 winchester. Do any of u by any chance know of any sites i could check that have the 3500winchester in stock. Thanks.
but is it stable or just as stable????? to run a 3200+ at 2.5 and the 3500+ at 2.5????
...i have to put some charictors in teh post window...
now whats that supposed to mean?????? i thought product now days were mass produced EXACTLY the same........
Doesn't happen. The silicon wafer isn't perfect, so some are better than others. If the 3200+ and 90nm 3500+ you are testing are both stable at 2.5GHz and equal settings, then they will perform almost the same. There is never a guarantee for overclocking, only for stock settings.
exactly.
