Thanks hope i can return it and what would be best 2 970 or 1 1080?
Yeah, if one doesn't have a UPS with a built-in power usage display a power meter like that is rather worth it. I've got a 6600k and 970 that only draws ~250W at the wall while under full load. (that includes a 20W monitor, a ~5W HTPC machine and a network switch)A Killawatt meter is $20 and will show you exactly how much wattage your system is actually pulling under use. My 4790k / 970 typically draws 320w max while gaming. Double that and even 600w is way overkill.
Power supplies are the worst offenders of "bigger number must mean better"
Keep in mind gaming generally does not stress your system to the max. You should always plan for a minimum of max load at your planned overclock levels + 10%.
Generally, PSUs are the most efficient at around 50% load.
With that in mind, I generally like to get something that the constant load wattage is about twice what I think the system will pull.
That also tends to help the longevity as well since form my experience, a PSU will tend to last longer and run cooler if it isn't loaded up to near maximum all the time.
Note how I specifically said "Full load". I specifically loaded up Prime95 and Furmark one day to get the thing that high. "Normal" gaming runs around ~220W (something I forgot to mention is the 6600K is indeed overclocked but not overvolted by much at all)Keep in mind gaming generally does not stress your system to the max. You should always plan for a minimum of max load at your planned overclock levels + 10%.
With video cards requiring less power now a days are 1000w+ needed? I was told to get a good power supply in case i wanted to SLI or Crossfire and well i guess i kinda over did it with a 1600w psu. Should i keep it or return it and get a 850w or so psu?
