Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
well seeing as you have an X850 XTPE it doesn't really matter that much to you, plus sli doesn't work on widecreen monitors right now, so sli is pretty much out of the question for you anyway. Crossfire's probaby gonna a better solution for you(if they have widescreen support).
Also the widescreen problems have been fixed to a certain extent, though there are some monitors that still exhibit problems. The 2405fpw is definately now working with widescreen + SLI though.
The G70 looks to be fairly interesting as the GTX seems to come with 1 dual link DVI port + 1 single link DVI port.
