DarkOne_BW
- Apr 21, 2002
First let me say that I've been using the Cisco RVS4000 (v2) across 60-ish locations. I've seen 3 that were lemons right OTB, and another 7 that exhibit configuration instability no matter the firmware they run.
I'm looking for a recommendation for an alternative small VPN firewall with the following features:
IPSec VPN (OpenVPN is not an option, already have established VPN running through ASA at home-office)
At least 4 VLANs
Able to assign different subnets to each VLAN
able to provide DHCP on each VLAN
ACL support
easy to stage multiple units (easily modified config files ala Cisco IOS)
I would use an ASA5505, but in order to support more than 3 VLANs I end up going WAY over budget. Each remote office has between 3 and 7 desktops, so thruput isn't nearly as important as stability. I'd like to stay under $400.
The RVS042 almost completely matches my needs, except the VLAN/DHCP support is terrible; I can't subnet VLANs or have DHCP work independently on the individual networks.
I'm looking for real-world experience with these devices please. Thanks!
At least 4 VLANs
ACL support
