Hopefully someone may be able to help us a little bit more with an issue we are having. We have 3x esxi servers running 4.0, pretty beefy with 2x 6core cpu & 32GB RAM each. They each run a terminal server (windows 2008 r2) and a couple of other machines.
We are having big big problems with terminal server performance, the cpu keeps spiking to 100% which is causing users to lag badly & freeze up. We have given the machines 4vcpus to try and take advantage of more cores and even reserved shares. Lots of other little tweaks here and there but nothing fixes it.
What's funny is that when logging into v-centre we can see the hosts are taking it pretty easy with cpu usage being between 9%-30% at the times when the hosts spike. Looking at individual vm performance it does not take full advantage of the 8800MHz it has assigned, only around half of it. Other VMs on the boxes are fine, very low cpu usage so it's just the TS boxes. Each TS box is on a seperate esxi server so it's weird that it spikes on every one of them.
Could this point to an I/O problem as the only common factor is the iscsi storage but why would this cause the spikes we are seeing?
I've tried to keep this short so let me know if you need more info! Help much appreciated guys!
