VBscript or Html help pls
sonnavi
i need to run a exe file in the my web page or i must entegrate my program my web page.
the other option is user when clicked a buton my program starts in my server without loading user's PC. how can i do this.
To make sure I understand:
When the user does something on a web page (submits a form, clicks a link, whatever) you want to run a program on the server. Right?
What you need to do then is use ASP (since you mentioned VBScript) on the target page and use the exec command.
Alternately, if you mentioned VBScript because that's what the program is written in, then it's easier to just make the program part of the target ASP file itself.
