VB.NET Web Services
FireFoxx74
Ok, I am having a complete ***** of a time with .NET Web Services, so I am hoping someone here knows more about the things than I.
We have a piece of software running on server1, which has it's own web service Q. All of this is linked through DLL's so I can't mess with it. Needless to say, it makes basic calls to a database on SQL Server.
I am writing a web service in VB.NET on server2 using Visual Studio 2003, we'll call it P for now. Essentially I am using P as an overlay to Q, joining some of the simple methods of Q together into more complex methods in P; which can be further called by other programs.
The problem is thus; every time I make one of these complex calls of server2.P->server1.Q, there ends up being resultant threads open (cursorfetch_1) on the SQL Server. These threads buid up and up until the SQL Server explodes.
As far as I can tell though, my code is legit. Can anyone else confirm?
I can't exactly remember my code, so I will pseudo it a bit below:
Web Service P:
Code:
    Quote:
    Function getClientID(clientName)
    Dim WSQ = New server1.Q
    Return WSQ.GetParticipantByID(clientName)
    WSQ = Nothing
    Function getNotify(clientID, URL)
    Return WSQ.GetAccessAssessmentNotify(clientID, URL),
    WSQ = Nothing
    Function getSchedule(clientName)
    Dim CID = getClientID(clientName)
    Dim ReturnList
    Dim ScheduleList = WSQ.GetScheduleByParticipant(CID)
    For Each Schedule in ScheduleList
    ReturnList.Add (getNotify(CID, Schedule.URL))
    Next
    Return ReturnList
    ReturnList = Nothing
    WSQ = Nothing
    ScheduleList = Nothing
Actual code from one of the methods:
Code:
 <WebMethod(Description:="Get a ParticipantID from a CSLogin")> _
Public Function getParticipantID(ByVal CSLogin As String) As String
'Security Header
Dim QMSecurityHeader As New uk.ac.essex.serntxx.SecurityHeader
QMSecurityHeader.ClientID = QMWClientID
QMSecurityHeader.Checksum = QMWChecksum
'First grab a QMWISe header
Dim QM As New uk.ac.essex.serntxx.QMWISe
QM.Security = QMSecurityHeader
QM.Timeout = 1000 'ms
'Declare Variables
Dim ParticipantID As String
Try
'We could pass this into a participant object, or we can just grab straight from the call
ParticipantID = QM.GetParticipantByName(Trim(CSLogin)).Participant_ID.ToString()
Catch ex As Exception
'Failed - Participant already exists?
ParticipantID = Nothing
End Try
'Return
Return ParticipantID
'Kill the QMWISe object
QMSecurityHeader = Nothing
QM.Abort()
QM.Dispose()
QM = Nothing
GC.Collect()
End Function
The 1st thing I would do is make sure all datareaders in web service Q are being closed in finally blocks or something similar such as the c# using block.
