I will be as brief and concise as possible.
Im running the latest version of utorrent and XP SP3.
My connection to my room is being run through powerline adapters which feed into a router (wrt150n) inside my house.
I have the comcast cable 10MB package.
Problem:
I have many things enabled for download, ports are fowarded properly, everything seems ok.
What im noticing is that my speeds will max out to 1.3MB (the sum of all the downloads) and then over a matter of about 5-10 minutes, my speeds will slowly decrease drastically, to the point where it will bottom out at ~100kbs.
To remedy my situation all i have to do is unplug the powerline adapter and replug it in and/or restart my router and i get full speed again, only to have it decrease shortly thereafter.
I have tried changing the ports, limiting my downloads, running very very conservative settings on utorrent as far as connections are concerned, only to no avail. My connection gets saturated as well and my download speeds suffer, only when utorrent is run. On the contrary though, my ping stays the same and i am able to play CS:S... so i find this whole predicament very odd.
I need some help, i really dont know where to go from here. All i want is the ability to pull at a steady speed. This doesnt happen inside the house via wireless, it seems. I think its only the powerline adapter, but i may be wrong.
-gabe
Problem:
-gabe
