USB wont boot..
angstmanic
Alright, so i got a new printer for xmas, its USB, but when i plug in the usb cable, my computer stays in the windows screen, when i unplug it, it will boot up fine.
Why is this?
win98se
Drivers ?
Conflict ?
Is the USB enabled in the bios ?
Do you use anyother USB devices ?
Other hardware ?
More info helps. :p
Luck......... :D
angstmanic said:
That's your problem right there! :)
If you have any other USB devices unplug them and see what happens. I have never heard of a USB device conflicting with another one before but with 98SE anything's possible.
