You got some serious life out of it! I believe the die package is different between the desktop and mobile parts, so I'm pretty sure they are not interchangeable.
with mobile AMD, even if the socket is the same, it needs to be the same generation. A S1 Chip from G2 will not work in a S1G4 board. Do your research and you'll be good.That being said, I've never seen a dead Turion. You're positive its not the mobo? The 1546 is kind of known for killing boards.
Stoly said:In my experience AMD cpus are more prone to failure from overheating than intel. I have a couple of keychains featuring dead mobile semprons.
yea that doesn't sound like a gross oversimplification at all!
I've never had an AMD CPU cook itself that wasn't my fault. sounds like you've been buying some cheap-ass laptops or you're doing something wrong
Wish i had a dual core turion in my laptop.
5 mins on Ebay, 45 mins with a small crosshead screwdriver and some patience and it can most probably.
You are dealing with the "value" market customer. Read: cheap assed folks that will lay the laptop on sand, on their bed, and even let their dog rub fur all over the vents.
When you deal with the Wal-Mart customer, NEVER blame failures on computing equipment. Especially tagging a brand.
What you should have said is that your cheap assed customers are negligent, and cooking any cpu they get.
Edit:
This can be viewed as more opportunities for business than higher end customers usually provide.
Not on a M9700.
Why not? Wont the motherboard take a dual?
Thats a bit crappy.
That model Dell is still pretty new, so how did it overheat so quickly or what makes you think the mobo is bad? you should be able to access the CPU and heatsink from the bottom of the laptop very easy, so clean that out? Was the heatsink totally clogged or something?
Personally I would not spend 100 or 200 bucks for a used motherboard from ebay or somewhere with no warranty and questionable reliability. Then add in the cost of a new CPU too if both the CPU and motherboard are bad, plus cost of labor to replace the motherboard, you are at 300 to 500 bucks.
You can get even a basic laptop for 300 to 400 that will be new with a warranty and will have a dual core, 4gb DDR3 memory, that is probably better than that laptop anyway.
i've honestly never had a dell survive more than 2 years before the motherboards cooked themselves.
lol you answered your first question in your postcough "dell" cough.. i've honestly never had a dell survive more than 2 years before the motherboards cooked themselves.
