- Jul 21, 2000
how do you guys sync the time on a windows network?
well in work i'm using the net time command on the users login script
but as the machines have a policy restricting them , the command doesn't seem to run successfully
so the user is restricted from changing the time therefore the script also fails.
anyone know any way around this?
o our domain controller is an NT4 server
(which doesn't have the Win2k w32time service)
i'm using a combo of WinNT, Win2000 and Win98 PC's
Originally posted by m1abram
Well one way is to install a Time Sync app on the machine, that can run with the correct privileges as a service.
Course I do not know much about windows scripting, however I would be interested in a sudo way to do that.
Another option would be to adjust the users priv. to allow them to change the time. This of course is probably not a preferred method though.
i was trying something like that
i got a free program called NetTime that can run as a service.
problem is i can't get it to sync with any of my servers.
the only thing it picks up are WinXP machines?
whcih is wierd
i am running some Win2k servers aswell and yet this program doesn't pick them up
yupOriginally posted by m1abram
I use NetTime also, the auto-config does not always work. Have you tried manually entering the time servers?
yup
using the IP and the server name and it just fails
the Windows Time service is runnign on the particular 2000 server i'm connecting to
what changes should i make to the 2000 server or should i make any? is there something i have to do to make the server advertise itself as a time server
