*MODS* If this is in the wrong forum, please move it for me thanks!
Hey guys, I have a 20x4 parallel LCD board with 16 pins. I'm trying to find the right way to wire it but I'm getting 2 difference versions of the schematics.
Here is one page with one version: http://www.geocities.com/krebnarb/lcdguide.htm
This is the second version: http://www.geocities.com/ResearchTriangle/1495/ee_lcd.html
In the spec sheet from CrystalFontz, pin 1 is for ground, 2 is for the logic (5V), 3 is to adjust the contrast for the LCD. Pin 15 is for LED+ and 16 is for LED-. The LCD voltage is 4.5V and current is 1.6mA, the LED voltage is 3.5V and current is 60 mA.
The questions I have are as follows:
1. What resistance/power rating do I need for a resistor for the LCD and LED if I'm using a 5V source?
2. Do I have to ground pins 18-25 on the parallel port to a ground point if I'm going to use the 5V and ground wires from a molex connector to ground pin 1 and 16 to the molex?
3. Would I wire the LED resistor in series to pin 15 from the 5V power and ground pin 16?
4. Can I use the wires from a cat5 cable to do the wiring?
