tcp/ip missing
the big guy
OK guys, I really screwed the pooch with this one. I was cleaning bad things from my registry (really bad idea btw) and now I am getting a tcp/ip missing error.
I checked the reg key for tcp/ip under this root
hkey_local_machine\software\microsoft\tcpip\currentversion
this is what comes up
name-default
type-reg_52
data-(value not set)
Is this the problem and how can I fix it?
Win XP pro sp1-legal copy
netgear 54g router
Amateurs should never mess with the registry, I know, but the stuff I was removing was from dead proggys so it shouldn't have created an issue.
ok, that would be great if I had any clue how to :D
Sounds good, but I have no clue, so please help.
ok, googled it and while doing the command line "netsh int ip reset resetlog.txt" with no quotes, I received this error "initalization function InithelperDll in IPmonitr.dll failed to start with an error code 10107
something looks majorly hosed
I just downloaded ipmontr.dll from another computer. Should I delete and replace the file on my borked one?
im with ya still if that doesnt work.. i can try to help more but im kinda noobish at networking as u can tell if u read my post "Freaky Errors"
Score 1 for the good guys. It worked and I am posting this from the formerly borked box. Weird that you utility could basically fix it using an automated method of exactly what I was trying to do, but I don't care, it worked!!!!1one--lol
Thanks a lot, I appreciate it
ok, your problems fixed how about mine :(
glad i could help\
also im removing the tool you downloaded sorry, that 1/10th of my webspace lol
