Hi all,
I built entire new system with the following:
AMD Athlon 64 X2 4200+ Manchester
G.SKILL 2GB (2 x 1GB) PC 3200
ASUS A8N-SLI Deluxe - ZALMAN 92mm as HeatSink - bios upgraded to 10015)
PNY GeForce 7800 GT 256MB
Ultra 600w X-Finity Power Supply
36gig Raptor as primary.
Plugged everything together, turned it on, and right away i saw artifacts on the screen, even in Bios. While installing windows it got worst. After everything was done, and drivers were installed, i saw the following.
Tried different drivers: 81.95 and 81.94, both had same effect. I also used second PCI-E slot to make sure it's not the mobo.
I returned the PNY 7800GT card, and got eVGA 7800GT card. I plugged it in to the same windows install and saw small artifacts. I made nothing off it and reinstalled windows.
Everything went smoothly, nforce drivers, and all.
When trying to install graphics Drivers 81.85 in the middle of the install the installation process looked like it crashed, and screen started to flicker. I went to Safe Mode, and uninstalled the drivers, tried 81.84. With those drivers, my screen went black, and neve recovered. So i tried to install gfx drivers without nforce, drivers, but same thing.
I went all the way back to 77.77 version, but same thing happened.
So my question is.
What is the problem, would that be a second GFX card i received, or a power supply?
I'm not sure, and have no idea what else to do.
and becasue of the damn TWU strike in NY i can't really go to a friends house to test anything.
Edit: Also here i sthe voltage reading from bios.
Vcore: 1.36V
3.3V voltage @ 3.31V
5V @ 5.05V
12V @ 11.77V
So my question is.
Vcore: 1.36V
5V @ 5.05V
12V @ 11.77V
