Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
Im having crazy situation. I just installed a MB Neo2 V (865PE), cpu & ram, etc. when plug the cord into the outlet it powers on by itself. I have yet to hit the power switch button.
The self booting has to do with a power state options in the BIOS. A computer can boot from LAN, keyboard etc.
As far as detecting the harddrive. Turn off RAID settings, try moving to a data SATA port, instead of setting the hard drive to auto detect have it manually detect the drive.
^ yeah it has to do with the power-up options in the bios. Most mobos can wake on LAN or wake on modem ring or a whole host of others. Just go and disable them all. Mine does that too if I enable the "wake on PCI" option in my bios...as soon as it shuts off it turns on again.
