Carlosinfl
Loves the juice
- Sep 25, 2002
I am confused about something...if you want to spread your DSL or cable connection to other nodes in the lan, they say to get a DSL or cable router.
Why do I need a router?
Doesn't a LAN switch or hub do the same thing?
What info do I need to route? I guess I am just confused about the difference between a router and a switch.
I though a router is only needed when to LANs merge or need to access each other
