Suggestions for loop order
AnimeMan
I have 1 pump, 1 rad, 1 cpu cooler with tec, and a res. Right now i can fit everything in the case, i just have to figure out what order to go from what to what. the rad is sitting right next to the pump, so...I was thinking (arrows indicate direction of water) :
pump --> rad ---> cpu ---> res ---> pump?
that look good to yall? thanks.
Looks great.
As long as you go reservoir -> pump, the loop order isnt a problem. Do what order makes the most sense for orginization and tube lengths.
I agree. With my rig, I moved stuff around in every which way to see if there really was a difference. The water temperature regulates after a while, and it makes no difference (that I saw in my tests).
