Steam Frame
flegg
No discussion about this yet?? Coming out soon!
Could be Quest killer? Basically looks like a Quest but with Steam access and better streaming. Sounds like gg to me? I'll be buying one ASAP.
It's not really a Quest killer, it's aimed at a completely different market and will be a much higher price.
The Quest headsets are primarily standalone headsets that can connect to a PC. they are aimed at those people without a PC and more for the mainstream end of the VR market.
The Steam Frame is a PCVR headset with standalone capabilities. It's aimed at the VR enthusiast who already has a PC and a Steam account.
Will you be getting one no matter the price?
Same. I've not been sold on VR after having, and eventually selling, many headsets over the years, and technically this one looks to be the easiest from a convenience standpoint to use with PC, without the quest 3 jank, and acceptable enough visuals. I outright refuse to give up a DP or deal with swapping DP just for VR(still no killer apps/games), so this one intrigues me.
The Steam Frame has no Display port. It's wireless only and roughly the same resolution as the Quest 3. Actually first impressions at the press release were talking about visual SDE. It will have pancake lenses, so that's a plus, but if you have any decent PCVR headset already, the Steam Frame will probably be a step back in both resolution and picture quality. To put it another way, some people prefer the Quest Pro and the PSVR 2 over the higher resolution of the Quest 3 for PCVR because of the OLED/MiniLED screens. If you outright refuse to give up DP and prefer the deeper blacks of OLED screens, then the Steam Frame is a non runner for you. And if it's priced at $1000 or more, then surely you would be better off saving a bit more and getting the BSB 2.0 or the Pimax Dream Air.
I really wish they would have used OLED displays, But I'll be buying one anyway. Cordless game play and some stand alone use hopefully make up for it.
Full on wireless is an actual game changer for VR. OLED is just nice.
I hope they come out with an OLED model later though. Maybe they will a year or two later like what they did with Steam Deck OLED.
The main problem right now is OLEDs aren't bright enough to make sacrifices like higher persistence or an extremely dim overall screen. But the tech keeps improving, samsung just showed a micro oled prototype that does 40k nits. That's almost 10X brighter than what is the app vision pro.
Correct...i use all of my DP ports on my GPU, specifically why I want wireless VR....so guess misunderstanding there? Also stated it wouldnt be up to par, but for PC and wireless, it checks the boxes i care about. $$ figure, we will just have to see. I'm not in a must have mind-set, but unless it is just unreasonable, I will likely pick one up.
if it does everything the quest3 can do, then, personally yes. but i understand the sentiment
Doesn't Sony make the Pimax OLED displays, couldn't Steam have used those for the same way Pimax does? I always wonder if you couldn't mod a Quest or Frame with the same displays.
It's not something the average person could do. The bulk of engineering for the headsets is put into getting the lenses and displays to work as well as possible. You would be pretty much making your own headset at that point.
It would be the equivalent of replacing your engine and suspension in a car.
Ah, when you said you wouldn't give up DP, I thought you meant you wouldn't give up a wired connection when using a VR headset. My bad.
What is unreasonable in your eyes?
It's better in most ways. Which is to be expected, it's a much newer device. It's worse in some areas though. As a purely PCVR device, it should be better. As a Standalone device, it's much harder to call.
$1200 is the max ill spend on principle. Prefer a $7-800, but with component costs etc these days, I'm not sure if that reality exists anymore.
Maybe they'll make one that's not a PC too later on. Unlikely, I guess, since you pretty much need everything that a PC has for something like this to work anyway (exception being so much RAM, and maybe cpu power), but maybe...
I highly doubt they will.
To get really good wireless you do need all of that hardware.
You need hardware to do space warping so the movement isn't janky with any wireless hiccups, to be able to do that you need head tracking on the headset itself, to be able to do that you need to do a bunch of other stuff, etc.
Then of course you need hardware for the stream decoding, a whole OS and interface for being able to connect to different host PC, set up your boundries, etc.
A bunch of complicated stuff that basically requires at minimum smart phone hardware. So you might as well make it stand alone capable at that point.
So it would have to be a wired only version to not be also standalone, and I think they really want to push full wireless because it really is a game changer for actual VR games where you actually stand up and turn around.
Well, I actually don't think the Base model will be more than $1000, unless things have gone seriously downhill in the last few months. Back in February Valve said they still plan on hitting that "cheaper than the Valve Index" price point. They didn't make any promises but I think it will look bad for them if they don't price it lower. I think it will probably be in the $900 to $979 range. If it's cheaper, great!! If it's more expensive, disappointing but not surprising.
My limit is lower than yours, $800 is my max budget.
It doesn't seem THAT much different than a Quest 3 and that's $600, I get that Meta isn't' incentivized by the profits of the hardware, but I don't think they're loosing money. So my guess for the Steam Frame is $800-900. The price where I tap out is over $1200.
The biggest distinction is the Frame has eye tracking. This improves streaming performance because you can do foveated streaming, and it can also improve standalone performance because you can do foveated rendering.
It also comes with a wireless dongle for PCVR streaming.
Basically it's optimized for wireless PCVR.
The Frame has Eye tracking, newer SOC, Expansion slots/ports, more advanced controllers, smaller form factor, wireless dongle and double the Vram. Even if Valve did the same as Meta and sold at break even, the Steam frame would still be more expensive.
What everyone forgets though is that the price that Meta sells the Quest 3 for is break even on BOM only, i.e. just the cost of manufacturing. The Quest 3 price doesn't include all the other costs of getting a product to market like warranty replacements, R&D, marketing, Shipping etc. etc. Valve isn't subsidising the Steam Frame like Meta is with the Quest 3. Valve are going to be including all those other costs in their final price.
So all these things are adding up to a product that is going to be at least $200 more expensive than the Quest 3, and that's not including whatever margin Valve is going to add on.
The Steam Machine price has made me doubt that Valve will release the Steam Frame at a lower price than the $999 Index.
Yeah, they said they wanted it to be cheaper than the Index, but I wouldn't be surprised if it is more.
At least with the Frame memory and storage are a smaller fraction of the cost, so there is hope.
Maybe they might decide to subsidise it. It's not like it's going to sell in large numbers in either case. And it's very unlikely many people, if any, will be putting another OS on the Steam Frame.
Unfortunately this thing has a SOC, RAM and storage despite being a PC-first headset. If it releases with primo 16GB LPDDR5x ram and 256gb/1tb options that is an expensive component list for someone mainly using it for PC vr.
i bet it sells well
It will sell out... because Valve will only make a half million of them.
Oh I know that. Like the Valve Index was always "sold out" yet sold less than 400K units.
That's why I am asking Flegg for his definition of "selling well" As in what numbers.
you first?
You are the one that said I bet it sells well. Are you not confident enough in that statement that you can't back it up with some numbers to say what selling well means to you?
Would you consider selling as many Steam Frames as the Valve Index as selling well? or The PSVR 2? The Quest 2? Quest 3?
The "You First?" reply is basically chickening out.
But here's some numbers for you. It won't move the needle in VR adoption at all. It's a premium VR headset for the enthusiast and it will mainly be bought by owners of previous PCVR headsets like the Valve Index who haven't upgraded yet and by those people who buy every headset. Very few new people to VR will buy the Steam Frame. I am sure there will be people who have been holding out for years and will take the plunge now and others who hate Meta and ByteDance who will buy the Frame, but there won't be too many of those.
Now we know that Steam Frame is been pushed as PCVR headset and the numbers in PCVR is tiny, 3 million or so. We know that the Quest 3, even at $499 didn't sell very well, the Quest 3S is outselling it. The Valve Index sold less than 400K in it's lifetime. The first Quest sold more in it's first quarter of sales. My point is that no headset over $600 has come close to selling a million units.
My estimates for the Steam Frame sales are that it will sell roughly 500K units in it's lifetime with maybe 200K in the first year. If, and this is a big if, there is a big drop in RAM and Storage prices over the next couple of years, maybe Valve might drop the price and that could result in increased sales for a while.
I am really curious to see reviews. I am interested in this, though I worry it'll be a bit difficult to obtain initially, but I will get my name on the list when it's available.
Reservations are live
That's very expensive, which makes me think the 1TB model is the best buy if you intend to do any stand-alone gaming. You're already paying a small fortune, so why not get the best you can?
It does support MiroSD and they claim you can install on your steam deck or PC and move to the Frame. I signed up for the 1tb, but would be happy with the 256 version also.
I regret getting the lower-storage Quest 3, so...yeah, if you can swing it, I'd go for the 1 TB.
