Greatone123
- May 10, 2006
I just recently got a new monitor so I went to a higher res of 1920 x 1200
I've got a 4870 1GB and I'd like to upgrade...
I've got a Phenom 2 940, 4GB ram, Foxconn A7DA-S 790GX
would there be a big difference if I just got another 4870 and used crossfire over shellin out the the large $$ for the x2?
some of my things are I've seen the coolers on the x2's and I had that design it's usually loud, and the Sapphire toxic 1GB 4870 looks like it has a better cooler on it with heatpipes and all... so heat and noise ar taken into consideration cause I don't want to buy an after market cooler for either of them.
performance/heat/noise which is a better solution..?
games: WoW, COD4, COD5, just got stalker clear sky... fallout 3...
