err - this isnt true. the circut works just as hard with one or two bulbs... they draw .05ma and it is a current regulator so its got to provide the same current if one or two bulbs are hooked up.Majin said:Also make sure you don't run more than 1 CCFL per inverter (even if it has a second plug for another CCFL) The inverter will last a lot longer.
Agreed 100%, good info...theshadow27 said:it looks like you overheated the inverter. did you stick it under something? they have to have some airflow, not nessesarly its own fan but at least not shoved in a corner. the little holes on top are for air![]()
chances are the bulbs are fine... xoxide.com sells $3 inverter replacements
Someone needs to test the current load on startup/running with dual versus single so this fistfight can be ended once and for all. Unfortunately, I have but one plug per inverter here so I'm as useless as CC lights in bright sunlight....Pherret said:If you double the load then the power requirements go up. That means more power going through the same inverter, and more heat generation.
Wether it actually equates to more dead inverters is something I cannot say. As to why so many let the smoke out, Id say bad quality inverters.
