Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
Well, one way is to add a second parameter to the lambda inside of not-divisible? If you have to use that exact template, you'll have to use curried lambda's.
