Does anyone know where I can get the entire control panel on the top of the case where the USB ports, power button, and reset button are located?
A few weeks ago the USB ports stopped working. I also have a lot of problems with the power button. If I ever turn the PC off I have to hit the power button about 20 times and get it just the right way for it to turn the PC on. Very annoying.
I looked at Silverstone's site and didn't find anything. Figured I would try here before emailing them.
still need to clean up the wires a bit.
Where does a person get that white wire kit? Came with the power supply?
Somewhere in this thread I saw an actual extension kit, but I haven't been able to find such on google. Where does a person buy an extension kit for the psu cables, to make them more organized? Or do you just buy each individual extension cable from Newegg or such?
I am having a hard time finding any pictures/evidence of people installing a 280mm radiator (corsair h110, nzxt x60, or custom) in the FT02. I want to know if this is possible without modding the case. Anybody know?
The hell is it with people trying to shove water-cooling parts into a premiere air-cooling case...
Why Silverstone haven't come out with 180mm AIO coolers for this wonderful case is quite beyond me. One cooler for the CPU and one each for two GPUs via the NZXT Kraken and any gamer would be in clover.
So anyone knows if you could put Swiftech H320 into FT2 and use 180 fans + 3x120 as push-pull configuration ?
Why is there no FT05 thread yet?
Did not realize until I saw this post and googled. I was so happy for a second when I thought it was going to be a FT-02 successor and was hoping for it to be a bit bigger so I can WC it. The FT-02 is just so hard to WC, they shrunk it so much that it doesnt meet my needs for ssds/hdds.
My rearmost fan (below the CPU) seems to be dying, as I have to crank up the voltage to get it to spin at even 650~ RPM. Considering replacing all three fans with AP182s.
Honestly, if this case had better wiring routes along the back, it would be perfect and I'd keep it into perpetuity.
I think you would see a couple degrees drop at the most with the AP-182.
If you already have a good fan controller the AP182's don't really make sense unless you need the extra rpms (and don't mind the noise) over the AP181. They do look nice with a white/black color scheme though!
The G1's heatpipe design is fine for the 90 degree orientation, and the case's intake/exhaust setup will deal with a single cards heat dump with little to no difficulty.
I am original poster lol. Is this case still king of the air coolers?
