Rambus
Kung
what mother board can i use with a p4 3.2 ghz and 1066-32p samsung rambus memory i just got a noraml mobo from abit and it dont fit and now im angry....
Unfortunately, you're SOL on this one. :(
All of the 3.2GHz P4 processors require OFFICIAL 800MHz FSB support (200MHz quad-pumped) - but the last Intel chipset which supported RDRAM supported a maximum official FSB speed of only 533MHz (133MHz quad-pumped).
The Intel D850EMV2 has support for PC1066 RDRAM. It was the last chipset that supported RDRAM but only supported 533MHz CPU's. It was launched just prior to the i865PE and I875P launch. So support for Prescott CPU's or any 800MHz FSB CPU is out of the question.
RDRAM frequencies are calculated by doubling the speed. Like DDR. PC800 RDRAM operates at 400MHz. PC1066 is 533MHz and is 32bit instead of 16bit for it's interface.
You can find information on this board here.
http://support.intel.com/support/motherboards/desktop/d850emv2/sb/CS-010463.htm
