Rack server for NAS
eof
I'm building a NAS server. I have an external 16-bay enclosure and the required RAID card for it. I'm looking at recommendations for the server part. My current idea is to get the following components:
1. Intel Core i3-3250 CPU
2. SuperMicro MBD-X9SCM-IIF Micro ATX mobo
3. Kingston KVR1333D3E9SK2/8G (2x4GB unregistered DDR3 1333 ECC RAM)
I'm still looking for good enclosures with reliable PSUs. Since I just moved to Europe I've been looking around European stores. I've seen some reasonable cases here:
http://www.xcase.co.uk/2u-Rackmount-Cases-s/25.htm
The server rack will be sitting in my home office, so I would need a machine that's pretty silent. 1U racks tend to have small noisy fans, so I think a 2U has more potential and at least I can switch the fans to something less noisy.
I would hope to get comments on the following:
1. Mobo choice. Any cheaper good boards out there?
2. If someone knows another store that sells great rack cases in Europe, please tell me.
1) Here in the U.S, the MBD-X9SCM-F-O is a tad cheaper and is far more widely used than the MBD-X9SCM-IIF.
2) N/A
What size case are you looking at? 2U? 3U? 4U?
I would like a case that's fairly silent, so a 1U with high RPM fans is probably out of the question.
Decided on the following:
Case: http://www.xcase.co.uk/product-p/case-316-pro.htm
PSU: F.S.P 2U 600W Single 80+
Mobo: SuperMicro X9SCi-LN4F
CPU: Xeon E3-1220v2
RAM: 32GB DDR3 ECC
SAS card: 2 x LSI SAS 9211-8i HBA
This adds up to a total of 1998 euros with shipping from X-Case. I'll check how much I could reduce the price if I bought the parts myself, but it might not be worth the trouble.
Now I just need some Seagate Constellation ES.3 disks and then let ZFS do its magic...
