lol i must say. BURNpopgoestheweasel said:Have problems hitting 3 keys at once?
Daita said:The winkey+L will instantly lock the computer as well if you're on xp and might 2000. Its almost as good as a dedicated key. You could also program one of the G keys for that combo to get a single key solution.
Booger said:It's a big keyboard, ok!?You try coming up with 54 commands for the G keys.
Bigshotdarktiger said:Easy, I have something like 40 shortcuts for photoshop CS2(actions, plugins, filters, brushes) alone....
