A friend of a friend asked for help protecting their home network, which also contains their home business pc's. A family member setup and installed all the hardware. They since have had a falling out and comments have been made about corrupting their files/systems. The family member has a bachelors degrees in IT, although I don't know what field. All I know is they have 5 pc's, some using wireless, with cable broadband and a router. I think the os being used is XP. I informed the person that it was likely the family member had access to the network remotely, most likely without them knowing. I imagine someone with a degree would setup a VPN or such. To prevent access while they aren't in their office I suggested turning off the router, hopefully preventing access. I recommended they consult a professional to reinstall all the OS's and networking, however I don't think they will. Any suggestions to help them protect their network from the installer? Personally I'd just start over with all the hardware, OS's, routers, etc. I appreciate any comment to help the person out.
