Aloha! I'd like to share with you my latest build, Coppernaut. I chose this name because 1) this build is heavily copper-themed, utilizing copper components, accents and mods and 2) the -naut suffix makes me think of the Greek Argonauts, heroes of the sea and adventurers. Water is fitting because I am designing custom and completely overkill watercooling for Coppernaut. Adventuring works because I will be pushing the boundaries of my own modding experience and my components. Basically, we're gonna get [H]ardcore here.
I'm also writing this log from the future, you could say. I began this project Sept 22, 2012, so I have a 1.25-year head start on you as you read this. The good news is this will allow me to write up the project chunk-by-chunk without waiting months between updates.
Many warranties were harmed in the making of this computer.
My goals starting out:
I'd love to see what you guys think and see if you have any more crazy ideas for me. It's 90% done right now but I can fit a lot into that last 10%.
So, without further ado, here's where we start.
As my case, I chose a Silverstone FT02B, which has a flipped-and-rotated ATX layout. The motherboard mounts on the left side, not the right, and is rotated 90° so the connections come out the top. Why did I choose this case? THE FANS! There are three massive 180mm Silverstone Air Penetrator fans in the bottom of this beast, which happen to go great with a 3x180mm radiator. Here's what it looks like stock.
Outside:
Inside:
So about $250 worth of case arrived and what do I do? Immediately disassemble it, of course. After much unscrewing and drilling out rivets, it's looking a little bare. Notice I had to remove the drive cage to accommodate the extra height added. But we can deal with these things. I'd seen people shorten them to three drives and remount them horizontally, so no big deal.
Mocked up with the radiator and fans. Sexy.
At this point, I bought a jigsaw (projects are great excuses for buying more tools
), went to town with the blue masking tape, then measured, marked, measured again, and measured some more.
No turning back now.
I also needed a template of the radiator opening, so I did this pencil rub.
Transferred to the case. This involved a ridiculous amount more measuring and checking.
Got the details cut out. This was followed by a shit-ton of filing. Steel is a pain to work with compared to aluminum.
Looking pretty good with the radiator in there.
My clearances were so tight on these tabs on the motherboard tray that I couldn't even put the fan screws in. But it holds tight nonetheless.
So that's what I've got for tonight. Next time we look at a new mounting system for the fan filters and setting up the watercooling reservoir.
Edit: Skydrive wasn't working quite right for hosting the images. Moved to Imgur.
- Hard copper tubing
- Extreme watercooling
- Black- and copper-themed components
- Combining some of the craziest ideas out there, plus a few of my own
- Built on the Haswell architecture (i4770K)
- Overclock the bejeezus out of it
- Minimal corner-cutting
Outside:
Inside:
