Strykar said:Got mine in today and I can't seem to get the remote to work. I went through the help files and it seems to need an IR reciever which was not shipped with the package.. Is this an additional upgrade or did it just get missplaced from my package?
hongsc said:Is the drive connected with the ribbon cable? Is the internal drive connected to a molex? Also you have to point the remote directly at the internal drive.
Problem is solved! Installed "Entertainment Center" restarted, works fine now! Only works with MediaSource apparently though, you can change EAX settings/volume/etc anytime, but the actual multimedia part doesn't workdderidex said:Keep in mind, the remote is only going to work with Creative's MediaSource software package.
Doesn't work with anything else. (Or, at least, it might - but it won't without the MediaSource installed first. IE., do a full install instead of custom and see if that makes a difference)
BBA said:And where do we find this app pray tell?
