jpnelson83
- May 13, 2002
Ok so, theres going to be some stuff coming up that I want to record and so I figured I'd go and make sure everything worked ok. Thats when the problems started. Everytime I hit record I get an error, it writes to the error log and then I have to restart the program. I found the error log but can't make heads or tails of what its trying to tell me so I figured I'd open it up to you guys to see if you could help me. The error log shows:
*** Log Manager 0: Opened on: 10/12/2004 [13:10:46]
[13:10:47] ResMngr::LoadObject CoCreate Error: ClassNotReg CLSID: {B6761AC7-0F95-4184-8CEE-0E8495BEBD13}
[13:10:48] TvDisp: StartUp: Failed to setup DTV Graph
[13:10:48] CCaptionControl_DS:Setup: Failed to Load & Connect WDM CC Decoder with ATI CC Renderer
[13:10:48] CCap:Caption: StartUp: Failed to initialize Driver
[13:36:12] CSoundControl_DS::SignalHasSAP: GetAvailableTVAudioModes() has failed
[13:37:06] CSoundControl_DS::SignalHasSAP: GetAvailableTVAudioModes() has failed
[13:37:23] CSoundControl_DS::SignalHasSAP: GetAvailableTVAudioModes() has failed
*** Log Manager 0: Closed on: 10/12/2004 [14:00:16]
For the record I'm using MMC v7.6, Catalyst drivers 4.4, umm other hardware includes a soundblaster audigy mp3+, gigabyte GA-7VAXP, 1 gig musking PC2700, and an Athlon XP 2800+ Barton. So I'm wondering if there is going to be any kind of fix for this or if I'm going to have to reformat or something. Oh directx 9.0c has been installed if that has anything to do with it. So any help would be apprecitated. If I'm better off posting this at htpcnews.com let me know and I'll do that. Thanks guys.
