i have a program that needs to print reports. On a ink jet print it will print just fine all the order numbers show up no ####. when i print the same report on the laser printer i get ##### for order numbers. Also on 4 different computers the fonts are all different. The font sizes on two of them are really small and you can't see them and the other two are big and you can't see the order numbers and the order numbers show up as #### numbers biger then 5. if you print from microsoft word everything looks normal. Is it the program or is it the printer? can i change the fonts that the computer uses to print or is the program handling this?
The printer is lexmark E232, and the program is easydispatch.
Thanks
Greg
Thanks
Greg
