This is a revision to a prior case I had made. It is a scratch build using metal pieces from Home Depot and plexiglass, with the exception of a reused 5 1/2" bay, part of an old motherboard tray, and a Lian-Li HDD cage.
Below is a picture of my previous case using the same materials. It was 4" longer, was not nearly as clean in terms of cuts and drillhole, and lacked a proper front grills. Only a few pieces from the front side were reused in the new build.
