Nova is the best app in the history of the Google Play Store!Nova on both![]()
I can't get Nova to change my Wake on LAN widget to green when the PC is off though the stock launcher was able to do so, what am I doing wrong?Nova on both
I'm a fan of the default Pixel launcher because I know how it's going to work after having Pixels since the OG Pixel. The last Samsung I used was an S8 and I wasn't a fan of the differences in the app drawer, etc. I would imagine that those who have used Samsungs for years probably feel the same way about the Pixel launcher.
At least IMO the Pixel Launcher has gotten worse while Samsung's has gotten better. The app drawer is the one area where the Pixel launcher has OneUI beat hands-down. Samsung's shade similarly trumps the Pixel, though. With Samsung, you don't have the top rows of your UI locked down by "At a Glance," either. Buuuut you're still stuck with 10GB of Samsung's trash system apps. There's no perfect solution, but a Pixel device running Nova is probably as close as you'll get.
I get what you're saying about Samsung's trash system apps, but fortunately, phone storage has been getting larger and you can always just swap out the Samsung apps for stock Google ones (at least last time I checked).
