pic on a window
make a template of the pic on cardboard and put that over the window and spray???
Never really heard of anyone painting a pick on a case window. You would have to do it with a brush or insanely slow like the painting of macroblack.
I actually have a stained glass insert for my case. I am currentley working on getting a more "old church" looking window now but they are damn expensive
my friend does air brush and he is freaking good. he painted his case and it is blue white and black flames. he painted the window and everything. painting a window isnt that hard. if its going to be one color then use car paint u can find it at a auto store near u. it doesnt flake or crack. using a brush will suck. you wil get lines and streeks in it. u want to spray.
Originally posted by jrbryner
Paint onto a transparency then apply the transparency.
That's not a bad idea at all, that way if you screw up, you just get a new transparency. It'd be a lot cheaper then replacing the whole window if you mess it up;)
I posted this before. I got ahold of some printable overhead transparencies. Im not trying to crap on a thread, but this is what it came out like :
