Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
That's a weird question. It assumes you don't have a P2 laptop and you might be looking for one.
There might be a P2 laptop with a 16MB video card since there are lower speed P3 laptops with 16MB video cards. The price difference between those 2 should be minimal, so there's no reason to get a P2 laptop.
Yeah I do a lot of traveling with the army and am deployed to the field a lot. I am basically looking for something I can Bungee cord to the desk in the back of my truck and not worry about it while I am off roading, then use it while I'm on shift or in my off time for a few things such as running roms and watching DVD's.
There are more modern "toughbook"/rough-style notebooks that are designed to stand up to abuse (meeting mil spec), but they do carry a premium.
Old Panasonic toughbooks from the P4-M generation should work just fine, assumign that you are (hopefully) running it off vehicle power, and not an internal battery.
Man you ae planning to be daring. I start sweating when I hit a pothole in my car, even with the laptop in a padded leather case siting on a soft leather seat...........
You'll want a mid-ranged P3 or better. I refurbish laptops, I get everything from 286's to Core Duo's, and I can't think of a single P2 era laptop that had 16 MB, the norm was about 4 MB in those days. And if you want to watch DVD's, a P3 600 is about the minimum on a laptop that can playback a DVD without being choppy.
As someone mentioned the old Panasonic Toughbooks, those are about as rugged as it gets. I have worked on some ex-Army laptops, and they were designed for that kind of torture. That's the route I'd go.
