Passwords On Folders
Scotty0ZX2
I have windows xp pro and i want to know if theres any way to be able to put passwords on folders, such as My Documents , so when a person would click on the folder, a password would open up first and then after you enter the right password the folder would open up, thanks for any help
i remember using magic folders a few years back. its a pretty small program.
natively no
but instead you can use EFS. That way the OWNER does not need enter a password but anyeone else won't even get access if they don't have the correct certificate.
