I have an old system which is running a P4 2.8 (Northwood I believe) and some PC 3200 RAM. The motherboard went out on it and I'm trying to find a replacement board that will work with my existing parts. The problem is that I'm not having much luck. It seems like the motherboards I find are for later generation processors than mine (which is understandable since this CPU is 6 years old). Question is: Does anyone know where to find a motherboard that will work with my P4 2.8?
Thanks,
Mike
Thanks,
Mike
