squad
- Oct 1, 2010
Which phone should I get if i could get it for the same price? Need a new phone for work and need help choosing one.
Note 3 because I don't like the buttons on the back of the g3, I think its a terrible design.
Ingenious design. Easier to hold phone. Not always hitting the side buttons.
Samsung should take a look at that feature. I no longer change the size of my chats and messages or frig the volume up or down
or try to shut off or reboot. But I could just be impaired in some way.![]()
I'm not really sure why having the buttons on the side or on the back really help you then, it seems you should go all soft buttons if you really dislike them that much.
I'll chime in. I've used the note 1 to 4, G2 and G3. When my wife shattered her G2, then accidentally ran it over, I gave her my G3 and "upgraded" to a note 4. I do enjoy the 4. It's a nice phone. Good screen and battery. TouchWiz is crap and it's bloated as hell. The G3 has just as good battery life and screen. I really can't tell any speed difference between the 2, but the ergonomics of the G3 are lightyear ahead of the note 4. Just way more confortable to use, and I have large hands. The double tap to unlock, super small bezels, back buttons and light skin I miss the most. The note is probably going away in favor of the G4, as long as LG manage to not screw it up.
OMG poor phone lol but yeah G3 does feel like it has a better feel/hold with the phone. What do you think of the LG software? It's not as bloated like the touchwiz? Thanks.
Lgs skin is very light. Think in between motos recent phones and htc sense. Thats where i would put it. I enjoy it where i have not had the need to root or install a custom rom
LG G3 has a built-in infra-red sensor and an app called quick remote, no longer need universal remotes.
The d851 for tmobile is 3GB, 32GB storage as well
Samsung has this as well. They have prebuilt in support for many different products.
but there's also a lot of Samsung phones out there to be repaired... So how's the repair rate per capita?I've repaired many cell phones. I see Samsung phones all the time. They have piss poor build quality. I've seen brand new Samsung with all kinds of problems, and their parts are stupidly expensive. I've seen a few G2s with a slight crack making the digitizer partially inoperable. Of the two, get the G3.
That said, the GS6 is working out the kinks right now. So it's probably wise to not be early adopters.
because the other dude I quoted mentioned it...I thought the options here were Note 3 and G3, not S6??
