New Build! Need Suggestions/Comments!
Moses08
Hey all,
I'm going to build a computer mainly for gaming. I will be overclocking. All prices are in CDN$ and are from NCIX.com.
Here's the parts list:
Case:
ANTEC SONATA II BLACK ATX 16IN MID TOWER CASE
$128.98
Motherboard:
DFI LANPARTY UT NF4 ULTRA-D MOTHERBOARD ATX S939 NFORCE4 ULTRA DDR 2PCI-E16 PCI-E4 PCI-E1 2PCI
$165.99
Processor:
AMD ATHLON 64 3200+ PROCESSOR S939 VENICE 2.0GHZ 512K L2 CACHE 90NM RETAIL BOX
$238.99
Memory:
OCZ DUAL CHANNEL PREMIER 2X512MB DDR PC3200 CAS2.5 3-3-7 W/ COPPER HEAT SPREADER
$128.53
Vidrocard:
ASUS EXTREME AX800XL/2DTV RADEON X800 XL 256MB 256BIT DDR PCI-E DUAL DVI VIVO VIDEO CARD
$363.99
Hard Drive:
SEAGATE BARRACUDA 7200.8 250GB SATA NCQ 7200RPM 8MS OEM HARD DRIVE $159.98
Optical Drive:
NEC ND-3520A DVD+RW 16X8X16 DVD-RW 16X6X16 CDRW 48X24X48 DUAL LAYER+R 4X INT IDE BEIGE OEM W/SW
$56.99
Monitor:
SAMSUNG SYNCMASTER 913T 19IN 1280X1024 0.294MM 700:1 8MS VGA DVI SILVER LCD MONITOR
$478.98
Keyboard:
LOGITECH INTERNET PRO KEYBOARD BLACK PS/2 OEM (SINGLE PACK)
$15.77
Mouse:
LOGITECH MX518 GAMING-GRADE OPTICAL MOUSE 1600-DPI USB SILVER-BLACK
$61.27
Fans:
NEXUS 92MM REAL SILENT CASE FAN BLACK 1500RPM 19.2DBA 27CFM 3/4PIN
$15.47
NEXUS 80MM REAL SILENT CASE FAN BLACK 1500RPM 17.6DBA 20.2CFM 3/4PIN
$12.20
NEXUS 120MM REAL SILENT CASE FAN ORANGE 1000RPM 22.8DBA 36.87CFM 3/4PIN
$22.32
DVI Cable:
GENERIC DVI-D/DVI-D M/M 10FT DIGITAL LCD MONITOR CABLE
$22.90
DVD Media:
TAIYO YUDEN DVD-R 8X 4.7GB 50DISC SPINDLE SILVER TOP
$27.98
Mouse Pad:
ACT LABS FUNC F-SERIES F10.S SMOOTH MOUSE SURFACE 11X17IN BLACK
$19.99
The total before shipping, taxes, and insurance is $1943.88.
The total after shipping, taxes, and insurance is $2235.51.
Here is some of the feedback I would appreciate:
1. Are there any compatibility issues?
2. Could I get better value somehow?
3. Do you know of any stores in Canada where any of these parts or others can be found cheaper?
4. Is the AMD 3200+ worth the extra money over the AMD 3000+ if you are overclocking (the higher multiplier seemed like it was worth the extra money)
5. Am I missing anything (I only have speakers for this system)?
6. Would you do anything differently?
Thanks a lot for your responses! Feel free to answer just the questions you want.
Canadian sites I've seen so far...
mocc.ca
tigerdirect.ca
canadacomputers.com
newegg is coming to Canada later this year.
I'd get a power supply if I were you. :D
As for processors, it's a tough call. I didn't know what to do myself so I went with a cheap Duron 1.8 GHz until I really see what's going on in several months. I just realized you can game AND download and other things at the same time with a dual core. They're coming out with a $345 US AMD dual core next month. The thing to consider is if you spend $200 on a CPU right now and spend $200 later on for a cheap dual core, then you end up paying $400 total anyway. So, maybe you could go with the cheaper dual core next month. Had I known newegg was coming to Canada, I would have held my breath for bit my tongue (whatever) until then because I've pretty much "studied" the buying situation in Canada and we really NEED newegg here. They say they build warehouses in the places they serve. That means no stupid delays and duties. I noticed a 10% "overcharge" on tigerdirect.ca on prices if you compare the REAL exchange rate (i.e., item on US site $100, on CDN site $135). They still have competitive prices though which is a clear indication to me the situation sucks. It's pretty clear from my order with them that they pay duties themselves at the border and ship it to you duty free (you still need to pay taxes).
BTW, I did read SATA was not recommended for first time builders because the number of problems you can encounter.
Other idea? Maybe consider 6800 GT or floppy drive in case your system is completely screwed.
fdd good idea.
Your build looks really good! If you arent' getting huge air cooling or water cooling, I'd reccomend the 3200+.
Other than that, it's a keeper.
Russ said:
fdd good idea.
Cool. Thank you both for the comments.
I'd get a smaller, cheaper case. You don't have that much gear, and unless im thinking of a different case, its fairly huge for what you have there.
Built a few budget systems with a 56$ coolermaster cavilier 3 and have been VERY satisfied.
*edit* i see its a midtower, its smaller than I thought. Still, you can buy a much cheaper case and spend the money elsewhere.
case: Sonata is a NICE case, if you want more *bling*, then go for a SuperLanBoy.
Monitor: I just picked up a 913T - excellent LCD for the money.
CPU & Multis: yeah, go for the 3200+, that 10x multi is nice to have. If you have the $$$, I'd say even go for the 3500+ because the 11x multi is even NICER to have. Pretty much guaranteed 2500 mhz on a 3200+ if your ram can do 210 mhz (thanks to the 5/6 divider), and w/ an 11x multi you've just got more room to play with. 3200+ will most likely suit your needs & price point more efficiently, however.
