My dad's work is a small business, but when a new computer arrives in the next few weeks and their wanting to network their printer, they are in need of an upgraded network.
Currently they have a Linksys BEFSR81
They have had it a few years, its an 8 port Router/Switch, and they currently have 7 computers plugged into it, but with the addition of a new computer and a networked printer, they would need at least 9 ports.
My question is this, should I just recommend them to upgrade to something better, like the Linksys RV016
Which is a 16 port hub, containing 13 10/100Mbps LAN / 2 10/100Mbps WAN / 1 DMZ, but cost 400$ (or possibly someone might know of another 12-16 port Router/Switch that is good/reliable/cheaper)
or should I simply get a 5 port hub and sort of create extra ports, I would use the 8th port on the router/switch and put that into the uplink of the 5 port hub, and then the server and new computer would run off the new 5 port hub, and that would give me 12 ports at the cost of an addition 50$ (though I would also like feedback to whether or not this would work, im not a networking guru, but it sounds like a pretty good plan)
they don't want a wireless network or a print server.. i already asked
