Here's what's up.
I'm doing an upgrade.
Before I had 2 HDDs each independent drives.
I am adding 2 more HDDs, and want these two to be in a Raid 1 setup as a 3rd non-boot drive (according to my OS).
So, I installed everything onto my new mobo:
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128519
and setup a hardware raid in the BIOS.
At first I had issues because it was trying to make the raid the boot disk, but I fixed this and loaded up into my original windows instalation. As you would expect, windows did not see any new drives.
I did my computer > manage > etc
and setup the new two HDDs as a 1TB dynamic drive and simple volume. Formatted.
At this point, it looked like I was golden! So I started moving some data onto the disc.
I wanted to test the raid and my data, and make sure it was secure incase of a spindel failure, so I turned my PC off and unplugged one of the HDDs in the raid setup.
Rebooted, windows showed the drive full of data - AWESOME!
Wanted to check the other drive, turned off my pc, swapped the plugs, and rebooted.
Windows shows me an EMPTY DRIVE!
SHIT! Help?
SHIT! Help?
