MS Outlook 2016
bender322
Hello,
I cannot open Outlook pst file. The error message occurs when i try to open it:
Outlook data file cannot be accessed
Please suggest me something for pst recovery. It is very important file
Thanks,
Jim
If it's over 2GB you'll probably have to pay for something to repair it. I've never been able to find a legit FREE .pst repair utility that works on files over 2GB.
Jim,
Error messages are quite common while working with MS Outlook email client. This error appears in case if the Outlook profile is corrupted or Outlook folders are moved across drives. For resolving this issue i can recommend this app
PST Recovery Set
Best Regards.
4 extreme n00bies posting in this thread...huh.
Anyway, yeah, either ScanPST or try creating a new profile and opening the data file in that.
